Keeping Front PTO Mounted
   / Keeping Front PTO Mounted #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I am shocked that I can't find this answer on the internet.
I have an x730, of course 2WD. Can I keep the 2000 RPM drive shaft for the snowblower on all winter? Other than clearance issues, I can't think of any reason why i wouldn't keep it on. Am i missing anything?
   / Keeping Front PTO Mounted #2
So, you plan on just removing the blower from the front but keep the pto shaft and hardware installed? Yeah, I see no problem with that. Do you then use the tractor for other purposes than blowing?
pulling a cart of wood is my only activity. I jacked the tractor to triple check clearance, and I seem good. But i don't know if I am missing something.
   / Keeping Front PTO Mounted #4
Not missing a thing. Only should need to remove it if/when mounting the belly mower.
My X485 has been 10+ years wearing the PTO shaft that will operate a broom. Not in the way as I don't mow with this tractor.
thanks guys!
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
1985 International X Con Semi (A50514)
1985 International...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
