Kerosene in tractor
   / Kerosene in tractor #1
Slab
Ny
Yanmar sc2400
Ok or bad to use it as engine fuel in an emergency?
   / Kerosene in tractor #2
It would probably run if it is hot enough. Them old duel fuel tractors ran on it.
I am sure others will have different thoughts and will probably end in a heated discussion.
   / Kerosene in tractor #5
Kerosene is thinner and will do less work per gallon than diesel. Kerosene is also more expensive than diesel. I would use kerosene in my tractor in a pinch.
   / Kerosene in tractor #6
Kerosene and #1 diesel are generally equivalent. In refining, kerosene/#1 diesel is the portion that boils off right after gasoline. It has less lubricity and a lower heat content than #2 diesel. The 1928 Case model CC I have in front of my place has a 2 fuel tank system. It starts and warms up on gasoline, but then is switched over to lower cost kerosene which runs through a heat exchanger to warm the fuel before going into the carburetor. I'd try to limit use of kerosene to prolong fuel pump and injector life .
   / Kerosene in tractor #7
Sure in an emergency, I would.
Before settling on stanadyne we used kero to condition our winter diesel.
   / Kerosene in tractor #8
I would add some 2 cycle outboard oil to the fuel for added lubricity so tyhe injection pump isn't damaged.
Perhaps at a 50~100/1 ratio for peace of mind.
   / Kerosene in tractor #9
At the local airport they run all the diesel powered equipment, including a large bucket loader, on jet fuel.
   / Kerosene in tractor #10
yeah.. I'd run it if I had to.. and add a lube to it.. it's more $$ than diesel #2 here.. so I doubt I'd be running it.. but you never know.. If I got some gave to me.. I';d burn it for sure..
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
