Keyed P.T.O.
   / Keyed P.T.O. #1
PCNH
Meredith NH
New Holland 1725
Where I have my 3pt blower stored for the summer is under cover, however the end of the P.T.O. shaft is hanging out from under the roof. I figured an easy fix would be to just remove it from the blower. I removed what I'm assuming is a shear bolt, loosed the set screw and it wouldn't budge. After further inspection I see it's keyed to the shaft of the blower. I ended up re-assembling everything for the time being, but my question is why is there a key AND a shear bolt? Won't the key defeat the purpose of the bolt? I say this is a shear bolt because this is the bolt my dealer looked at reference when I told him I had taken it out. The one I broke was up near the tractor P.T.O. shaft. The P.T.O. is a Comer, from Italy. Thanks.
   / Keyed P.T.O. #2
I think the shaft to the blower may be configured to accept different kinds of PTO shafts. Just because there is a key in the shaft doesn't mean that it is being used.
I just mentioned in another recent post that I used to swap the PTO shaft between my tiller and blower. It's no fun. I suppsoe it is possible that there is a puller that you can use. I just proceeded by gently tapping the PTO shaft off with a wooden mallet, a little on each side. There was a tendancy for the shaft to go crooked, so I used a pry bar on one side while tapping the other. The pry bar slipped and I ended up damaging the oil seal on the gear box.
Ideally, I would leave the PTO shaft in place. Make sure it is hanging down from the gear box and cover the end. You could also slip it apart and store the "tractor side" somewhere else - again letting the attached end hang down (but off the ground) and covering it.
   / Keyed P.T.O. #3
If there is a key on the implement input shaft then the bolt there is not working as a shear bolt. There are different kinds of set ups for shear bolts. Sometimes there are flanges on the implement end of the PTO shaft with a shear bolt holding the flanges together. There ought to be some kind of system to prevent damage to the tractor should the implement stop suddenly.
Chris
   / Keyed P.T.O.
pbenven, that is exactly what I did, slid off the tractor side and protected the dangling implement side.
pennwalk, that is my set-up with the flanges up near the tractor P.T.O.
Thanks.
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
1974 IH Farmall 1066 Tractor (A50514)
1974 IH Farmall...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
PALLET OF MISC LINCOLN ARC WELDER, AIR COMPRESSOR (A51244)
PALLET OF MISC...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
