King kutter bush hog not performing like I need it to. Help.
   / King kutter bush hog not performing like I need it to. Help. #1
Jburks2
Ls xr4145
First let me start of by saying I just joined tbn. I must say what a great place to get help and share things! Let me start by saying I first had a ls xg3135 with ag tires and a cheap 5’ Andy500 bush hog. And it cut really well which I liked because I do bush hogging and land clearing on the side. So the time came I’ve grew and needed something bigger. So I went with a ls xr4145 cab with “industrial tires” because I liked my first ls so much. Anyways, along with it bought a pretty well built king kutter 6’ bush hog. Supposed to be faster and better right? 10hp more 1’ wider cut. Not really the case. I cut some big lots in subdivisions and on the first lot with new tractor noticed that the cutter discharges right out of the back straight into the tail wheel which then rolls the thick grass and leaves big balls of grass that doesn’t look so well. So what I did eventually was cut bolt holes on the back and put a piece of old thick conveyor belt over the discharge as a flap
Kinda. Works good until you start cutting heavier stuff and it starts shredding the conveyer belt. Then I noticed it leaving grass and weeds here and there on the edges of cut. Almost like the tires are smashing it down and the bush hog not picking it up or picking it up a little and cutting it half way up and still leaving half standing. So then I find myself cutting half back which doesn’t speed up the process at all. I’ve done every adjustment I can to try and make it cut better. I’ve done research. I’ve heard that blade speed hurts suction. I’ve read to get better blades etc etc. bottom line I’ve got to make people very pleased with my work when I get done Because that’s who I am, and sometimes it leads to heavy equipment getting brought in for me to do more work after I get finished bush hogging. I wanted to get the expert opinions on tbn before I start spending money. I’m open to all options. Thank you!
   / King kutter bush hog not performing like I need it to. Help. #2
OK Jburks2 . . . you tried the rear flap . . . sounds like your BH was designed for a rear discharge so you blocked it off hoping it would chop it up and keep the mass out of the tail wheel . . . did not work so well . . . maybe try chains on the back to break it up? That's what I have on two of my hogs seems to work well . . . also have a flail that gives a much better cut.
It definitely helps keep everything from shooting straight at the tail wheel. One thing I thought about doing was fab a metal plate around the back to keep from having to replace rubber flap and also add more lift/mulching to help cut grass bush hog is leaving?
   / King kutter bush hog not performing like I need it to. Help. #4
You do know what I am talking about putting chains on right? . . . it breaks up the discharge but does not trap it.
Oh for sure! What about the stuff it’s not cutting? Any suggestions
   / King kutter bush hog not performing like I need it to. Help. #6
King Kutter are not exactly top of the line. More like inexpensive and you get what you pay for. I have one. Not too impressed, but it does what I need it to do. I too have the same problem. I find myself overlapping my previous cut attempting to pickup and cut what the tractor wheels pushed down. Its just the nature of the beast. Chains on the rear will help with the clumping, also, slowing down and letting the blades mulch the material will help.
If your looking for a great finish in the lots, then you probably need a finish mower or offset fail mower designed for cutting grass (Y-blades). It sucks, I know.
   / King kutter bush hog not performing like I need it to. Help. #7
Great post Avenger . . . if he is looking for a great cut (who isn't) flail is my choice, but depending on how often he cuts . . . a good BH is the way to go and slow down to your tractor's HP sweet spot.
Flail mower is a no go. People aren’t going to pay for me to come out more often to cut it before it gets to high. This south bahai grass will shoot up over night. Most of the time I bush hog when it’s a foot high or more. I’m not asking for a beautiful picture perfect lawn look. I just need to get full 6’ passes without leaving grass still standing here and there all over. Maybe I need to get a super expensive cutter? What brand?Maybe check with my dealer to see if he’ll help swap out my tires to ag tires to not mash down the grass as bad. I’m not sure
   / King kutter bush hog not performing like I need it to. Help. #9
OK . . . I wish FWJ was here . . . you then need a better hog period and now that you know a few things I believe you are better suited for a commercial hog.
   / King kutter bush hog not performing like I need it to. Help. #10
I have a 6 ft mahindra hog , which is a grizzly made mower, it cuts great , I cut very tall thick stuff , It mostly mulches it up. I also have an old woods 7 ft cadet , that cuts really nice,
2019 Peterbilt 520 McNeilus Front Load Garbage Truck (A45336)
2019 Peterbilt 520...
2004 MACK CH613 (A47001)
2004 MACK CH613...
18' Bi-Parting Gate (A46443)
18' Bi-Parting...
24ft Corral Panel w/ 12ft Gate (A47809)
24ft Corral Panel...
JCB 525-60T4 Hi-Viz Telehandler (A47809)
JCB 525-60T4...
JMR 36in Bucket (A47809)
JMR 36in Bucket...
