King Kutter gear grease change
   / King Kutter gear grease change #1
sigjig
I have a King Kutter 5' mower. I was wondering the easiest way to change the gear grease in the gear box. Also, is 90-140 weight the grease to use?
Thanks, Sig
   / King Kutter gear grease change #2
If you have a loader, lift up the side opposite the fill to level plug... remove that plug and allow it to drain. If you don't have a loader or you do not want to lift it use a suction pump, either electric or manual, either method works well, I've used both just remember to have something attached to the 3pt for ballast if you use the loader to lift it.
I switched my gear boxes to synthetic lube, they all are running a lot cooler. The heavier wt. lubes like you have are very good for summer mower gears. May be too thick for winter, snow blower use... KennyV
   / King Kutter gear grease change #3
On my cutter the top removes with just 4 bolts.. I then sucked it out with a syringe. I think removing the top is much easier way to check the fluid level than thru the fill hole on the side..
Brian
   / King Kutter gear grease change #4
I forgot to add - Used amsoil Severe Gear 75w90 in mine..
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
