Oil & Fuel Kioti 84" Finish Mower
   / Kioti 84" Finish Mower #2
I think all of these use SAE 80W90 gear oil. This mower is actually made by Sicma of Italy. Sicma makes a good quality mower that is sold under many brands: First Choice, Kleen Kut, Kioti, Phoeniz, Farmmax, Deere, and probably others.
   / Kioti 84" Finish Mower #3
I have a KK finish mower and it takes SAE 80-90 gear oil. thats a safe oil to put in. Its got about 4000 acres on it now with no gearbox troubles .. . John
   / Kioti 84" Finish Mower #4
Also, if you store your machine in the weather, cover the gear case vent to keep rain out.
I noticed the characteristic "white" (water in oil) in my rotary cutter grease when I changed it last fall because my cutter sat out in the weather. I'm sure a little water would eventually cook off with use but maybe not before starting corrosion.
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
Cat 60" Wheel Loader pallet Forks (A49461)
Cat 60" Wheel...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
