Hi, I have read treads about gp but did not find any related with my problem: the gp indicator light remains lit even after starting the engine. In fact, it turn off only after the cooling fluid temp increase (1 or 2 min after firing up) The dealer send me a new controler but that did not solve the issue. I check connectors at the battery and at the gp relay and everything is ok (new tractor, only 35 hours) Also, I put a test light on the gp terminal and current is passing when the key is ON and the indicator light is lit. Any tought?
