Kioti CS2610 ignition switch
   / Kioti CS2610 ignition switch #1
DodCX
Iseki TX100f
Hello there, I'm new to the group and I have a CS2610 which appears to have a faulty ignition switch. Tractor starts when battery is charged but battery is drained if left attached when not running. Also have some intermittent dash lights flickering and machine attempts to preheat repeatedly when the key is not in the ignition and even when switched to off.
Can anyone advise on the particular model of ignition switch for this machine? Original switch has a preheat position to the left of stop position. ACC position is to right of stop and two further positions to the right, ON and then the furthest to the right being the start position.
There seems to be plenty ignitions for CK2610 on the web but I am not sure if that matches the CK2610.
Any advice appreciated. Thanks
DodCX
2018 FORD F-550 ROUSTABOUT (A47001)
2018 FORD F-550...
Pequea Hay Wagon (A47809)
Pequea Hay Wagon...
Bobcat 72in Skid Steer Snow Plow (A47809)
Bobcat 72in Skid...
2004 Ford F-150 XL Enclosed Service Truck (A45336)
2004 Ford F-150 XL...
FRUITLAND VACUUM PUMP (A47001)
FRUITLAND VACUUM...
Morra 2270 Hay cutter (A47809)
Morra 2270 Hay...
