Front-End Loader Kioti DK55 Loader
   / Kioti DK55 Loader #1
htalllen
Brandon, Ms
2010 Kioti DK55
I have a 2010 DK55 Kioti with front end loader. The cable that lowers the boom broke where it attaches to the joystick and l can't lower the boom. Is there a relief valve for the hydraulics that I can use to lower the boom so that I can transport the tractor to the repair shop?
   / Kioti DK55 Loader #2
I would imagine you can trace the cable back to the valve block and manipulate the valve by hand to lower the loader. Or trace the hydraulic hoses from the loader back to the valve block. It's probably just below the floor board on the same side as the joy stick.
Is it under warranty? If not you might consider getting the cable and replacing it yourself. It should be fairly easy to do.
Edit... I see you've just arrived here. Welcome!
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
