Kioti ds 4110 electric pto failure
   / Kioti ds 4110 electric pto failure #1
bondroad
Corinna, Maine
kioti ds 4110
I have a 2010 Kioti DS 4110 tractor with 302 hrs on it was using finish mower and the pto started slipping, not impressed, has anyone else had this problem with this type of pto on this tractor?
   / Kioti ds 4110 electric pto failure #2
The finish mower's belts might be slipping, Have you checked them?
the pto shaft stopped turning
   / Kioti ds 4110 electric pto failure #4
If this has a electric clutch you might check for loose, Torn or bare wires at or in the clutches area.
   / Kioti ds 4110 electric pto failure #5
Maybe a bad switch. That would be my first guess.
   / Kioti ds 4110 electric pto failure #6
My DK has a three pos'n switch for elect PTO, On/Off/Auto. Does your's have this feature and does it slip in both modes? I think Auto is linked to draft lever position so if lever switch is activated, (i.e. implement raised, pto is stopped).
   / Kioti ds 4110 electric pto failure #7
If your unit is out of warranty do the following: Check the fuses. Next disconnect mower check for rotation of shaft. If shaft rotates you will have to check pressures. If it does not check wires then disconnect plug and check solenoid for continuity. Past this you will need a service manual or take to dealer.
When I switch the pto on it will start the pto shaft but as you increase rpm's the clutches just slips and will not increase the shaft. I tried it on my tiller and does the same thing.
   / Kioti ds 4110 electric pto failure #9
As much info as you can provide to us helps us help you.
Have you done the scheduled maintenance and fluid changes on this machine?
Is it an HST or gear?
Is it still under warranty for the PTO?
Who's your selling dealer? Have you spoken to them about this issue yet?
   / Kioti ds 4110 electric pto failure #10
Sounds like the PTO clutch is slipping. How much free play do you have in the clutch pedal? It should be about 1". It is possible that the pedal is out of adjustment causing the clutch disc to slip. If the pedal is adjusted propery then it sounds like clutch replacement. Hope I you are still under warranty. Good luck.
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
LMC LOT NUMBER 259 (A53084)
LMC LOT NUMBER 259...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
