Kioti LK3054 rear vent blowing oil
   / Kioti LK3054 rear vent blowing oil #1
34Willys
Glide,OR
'18 Kioti CK2610HST
Just replaced all the hydraulic hoses on my Kioti tractor's New Holland back hoe attachment, and now after running it, hydraulic oil is blowing out the vent tube from where the return line Tees into the rear end. I've had this happen in the past, but seemed to clear up on it's own,
Is there a procedure to eliminate the oil blowing out tube, or does it just take time to cycle the air or what ever is causing the mess.
It seems worse that I remember before.
Is there something else I should be concerned about?
Patrick
   / Kioti LK3054 rear vent blowing oil #2
Send some pictures. My lk3054 has a PTO pump for the backhoe
Thanks for the reply.
I don't have the tractor nearby to take pictures, but it uses the main hydraulics valve of the tractor that you switch hoses like a manual power beyond.
   / Kioti LK3054 rear vent blowing oil #4
If you are using hyd. quick connects ( rear remotes )? make sure the return is connected properly . I'm alittle confused as to how yours is plumbed though ?
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2007 PETERBILT 379 MID-ROOF SLEEPER (A52472)
2007 PETERBILT 379...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
Husqvarna YTH18542 42in Riding Mower (A51694)
Husqvarna YTH18542...
