Kioti Rx7320 no crank
   / Kioti Rx7320 no crank #1
SailingMaster
Kioti
Hey all,
I have a Kioti Rx7320 that will not crank at all. I was brushhogging a field (grass and weeds, no sticks) and the tractor shut itself off. No beeping, no CEL, and no coughing before it died. It just acted like I had shut it off going 2400rpm. Trying to recrank, the lights on the dash turn on, however the solenoid doesn't even click when I try cranking.
I've checked the battery posts and cleaned them. I cleaned the ground connecting to the battery. I made sure the PTO was off. The tractor is out of gear and the shuttle is in neutral. There is no water in the fuel (plus no light on for it). My seat is unplugged, so it's not a problem of weight. The main fuses at the front of the tractor look good. The fuses in the operator's station look good. I'm outta ideas... Unless the computer croaked on me... Any suggestions, ideas?
Thanks all!
Jack.
I figured it out! It was my sear safety switch. It had come loose and was only working depending on the bumps.
Glad that was all!
2007 and Up Dually Bed for Ford (A44391)
2007 and Up Dually...
2016 Ford E-450 Super Duty Incomplete Vehicle, VIN # 1FDFE4FS7GDC05440 (A44391)
2016 Ford E-450...
2025 Swict 78in Bucket Skid Steer Attachment (A44571)
2025 Swict 78in...
2015 Ford F-150 Ext. Cab Pickup Truck (A44572)
2015 Ford F-150...
2007 INTERNATIONAL PAYSTAR 5900i DAY CAB (A43004)
2007 INTERNATIONAL...
2012 Isuzu NPR Truck, VIN # 54DB4W1B4CS803964 (A44391)
2012 Isuzu NPR...
