Kiotii dk55 blowing fuse on stop solenoid circuit
   / Kiotii dk55 blowing fuse on stop solenoid circuit #1
firemandan774
Kubota 4760 HST
Does anybody have a wiring diagram for a Kioti DK 55 specifically tthe stop solenoid circuit . It keeps tripping fuses when I turn the key on remove the solenoid and all is good engine starts but I have to stallb out to stop. Stop solenoid is brand new so I don稚 think it痴 that it痴 a wiring issue somewhere in that circuit. Thanks
   / Kiotii dk55 blowing fuse on stop solenoid circuit #2
What year tractor
   / Kiotii dk55 blowing fuse on stop solenoid circuit #3
If you just unplug the solenoid and turn the key on does it blow the fuse.
Does yours have a start and a run coil in the solenoid is it connected wrong.
Have you tryed a new relay for the solenoid.
   / Kiotii dk55 blowing fuse on stop solenoid circuit #4
Yes, yes...
Also ...
In this day, just because something is new, does not mean its good.... Might want to check winding values with ohm meter or do some bench testing ...
   / Kiotii dk55 blowing fuse on stop solenoid circuit #5
If he removes solenoid and all is good as he says, it’s probably not a (hot) wire shorting issue, as that would still occur. Unless shorting through solenoid.
Does fuse blow instantly (like a short) or does it take a second or two ( like an overload)?
Does new solenoid draw too much current? By defect or by design? Perhaps measure ohms of new solenoid? I think 12 volts divided by ohms will be approximate current draw.
Sorry for late reply I kinda got away from looking at the tractor since this whole pandemic thing started. Any how I was back this weekend and I replaced the solenoid as it was not working . The new one worked as it should but after a few minutes the tractor shut off and the solenoid was quite warm to touch. I disconnected solenoid used test light and pull in coil wire energized with key to on and goes out after a few seconds. Hold in coil stayed energized until key was turned off. You spoke of a relay where would this be found and what is it’s purpose.
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
Toro Zero Turn (A50324)
Toro Zero Turn...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
1994 Chevy  2500 Dually Pick Up Truck (A50515)
1994 Chevy 2500...
2015 CATERPILLAR 926M WHEEL LOADER (A51242)
2015 CATERPILLAR...
