kk 48" tiller slip clutch
   / kk 48" tiller slip clutch #1
gregg17
I have a new xb tiller. I was using the tiller today and got a rock jammed in it and it stalled the tractor shouldn't the slip clutch prevent that or do i have to adjust it i read the Manuel and did not understand that. I do not know anything about slip clutches any help would be appreciated Thanks
   / kk 48" tiller slip clutch #2
Usually the slip clutches are preset at the PTO factory and may need to be adjusted for each size tiller they go on and also soil type plays a factor. Many Tiller Mfgrs buy shafts from who ever has the best deal and you are kinda on your own when setting the tension on a new one as they change vendors from time to time. Ken Sweet
   / kk 48" tiller slip clutch #3
yeah- slip clutch supposed to prevent it. Its not adjusted properly. I loosen the all nuts pushing on springs until spring rattles. Then I test to make sure tines doesnt rotate by leaving it on ground and engage the the pto. IF the tines still turns, the clutch might be rusted together.
hopefully, you will have the manual for your slip clutch- it will tell you how much the springs should be compressed when you tighten up the nuts.
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
TAKEUCHI TL12V2 SKID STEER (A51242)
TAKEUCHI TL12V2...
