knocking starter on 5105
   / knocking starter on 5105 #1
daRedbone
Prairieville, La.
John Deere 5105
I turn the key and get some quick knocks coming from starter area before the starter begins to turn engine over. Number of knocks varies but 5 or less. I suspect solenoid but thought I'd check here before throwing parts at it.
It just passed through my little mind as I started it a few minutes ago, it may be the battery. I'm accustomed to a constant almost buzzing sound in vehicles and they never turn over after they do that. I'm still thinking solenoid though.
   / knocking starter on 5105 #3
Could be any reason, the solenoid would be my last guess.
Check battery, charge and load test, check battery cables and ground wires. You might find one or more issues in that area.
   / knocking starter on 5105 #4
I would check the starter to see if it is loose. If the starter is not loose, I would then check the flywheel to see if it is loose or missing teeth.
   / knocking starter on 5105 #5
Is your tractor running again? What did you find?
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
