Kobelco sk025 arm cylinder leaks
   / Kobelco sk025 arm cylinder leaks #1
PUDGY123
Eau claire wisconsin
Kobelco sk025
Hey all
Just got a older kobelco excavator and the arm cylinder started leaking, where does a guy source a rebuild kit? tried the local kobelco dealer and they said nothing is available. tried ordering aftermarket but the kit is way to big for my little cylinder. part #PV01V00010R300 any suggestions would be great
   / Kobelco sk025 arm cylinder leaks #2
Take the cylinder apart and head to your nearest competent hydraulic repair shop. All those parts are avail individually. I work on obsolete cylinders routinely so don't let anyone tell you differently but you will have to completely disassemble (including untorquing the hyd rod nut). Make sure you get a new rod gland DU bushing too.
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2025 K2223G UNUSED Double Garage Metal Shed (A53117)
2025 K2223G UNUSED...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
