Kodiak 6' medium duty deck mower uneven HELP!!!
   / Kodiak 6' medium duty deck mower uneven HELP!!! #1
Jmsmithy
Bronze Member
Russia, NY & Socialist Republic of NJ
2013 Kioti DK40SE HST
Hello All
I'm new at the whole tractor, implement world. I have Kioti DK40SE HST w/ Kodiak 6' Med duty mower. My tractor was delivered w/ mower attached. I used it for few hours, slowly learning. I parked, removed he mower from 3 pt and parked the tractor. Few days later I reconnected ( no easy task but I figured it out) the only issue now is the mower doesn't raise/lower evenly. :confused:
When I raise/lower the mower the left side comes up last/gets down first!! It holds evenly though, I think. I checked all connection and all pins/arms etc are even on each side....:confused2:
   / Kodiak 6' medium duty deck mower uneven HELP!!! #2
First guess, one of the links (generally the right one depending on how things are installed) has an adjustment for tilt. Crank it up or down to level things up.
Only option I can see for locating something like that without a lot of hit and miss guesses or have someone look who is familiar, is to break out a tape measure and compare one side to the other to identify the source of the droop.
A picture uploaded here might give you some results too.
   / Kodiak 6' medium duty deck mower uneven HELP!!! #3
Yup. It's my guess that the vertical link is the adjustable one, and that it wasn't dogged down during mowing. Vibration and gravity caused it to "unscrew", which obviously makes it longer. If that proves not to be the case -less common but still possible - the left upper lift arm may have jumped a cog.
//greg//
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2022 KMC 5610 LOT IDENTIFIER 197 (A53084)
2022 KMC 5610 LOT...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
UNUSED AGT ATK-TC24 TIRE CHANGER (A51248)
UNUSED AGT...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
