Talmidge101
- Joined
- Apr 22, 2009
- Messages
- 2
I need some help with a Sears Garden Tractor. It has a Kohler 20HP V-Twin
engine. It started fine this spring after storage. I drained the gas last fall and ran it dry as I usually do. After adding gas, I mowed for about an hour and then began to have trouble. It died as I was shutting down. When I restarted, it would run at low idle but when I increased the RPM it began to surge and then died.
I have replaced the fuel filter(it wasn't the problem) and checked the air filter. It is dirty but not bad. It acts like what i have experienced with push mowers when the governor is messed up. It starts easily but won't run very long unless I increase the RPM to max and then it surges and shakes. It may continue to run or die if I reduce the RPM. I have had no trouble with it before now.
Any ideas on what may be wrong ?
