Kohler Command 20 valve/guide question
   / Kohler Command 20 valve/guide question #1
Jbsims
Case 380
I'm rebuilding a CH20 64554 out of a Walker mower. I got it cheap because it needed a head gasket. I replaced the head gaskets, and that helped, but it was still burning too much oil. I tore it apart again to replace the rings. While I have it apart the second time I am trying to be more diligent about replacing worn items. The valve stems appeared to me to be out of spec. The Kohler manual says the intake valve stem diameter should be no smaller than 6.982mm and the exhaust 6.97mm. Mine were 6.93mm (intake) and 6.94mm (exhaust). So I ordered new valves from Lil Red Barn ($80). I was surprised to discover the new valves were no better. The stem diameter on the new intake valves is 6.94mm and the exhaust 6.95mm. My guides appear to be in spec but if I put the new valves in the "Valve Stem-to-Valve Guide Running Clearance" is going to be out of spec. Should I return the new valves and just run the old ones? Or keep hunting for OEM valves? Or just run the new ones? I am doubting myself because I was watching a Youtube video on measuring valve stem diameter that recommended comparing the worn part of the stem (the part that wears against the guide) to the rest of the stem. On my old valves, even though they are out of spec, they appear to be out of spec for the entire stem. There isn't really a worn spot. Of course, the old valves may not be OEM either. Any advise appreciated. I might take the head, new valves, and old valves to a local machine shop and have them check it out. Maybe they can knurl & ream the head enough to get it within spec. Another option is to exchange these for the .25 over valves and have the guides reamed to fit.
   / Kohler Command 20 valve/guide question #2
Those walker engines get dusted a known issue with them.usually they just get replaced. Not worth the time effort or expense to repair them when it happens
Thanks for the reply. What do you mean by "dusted"?
   / Kohler Command 20 valve/guide question #4
Google it. The walker mower is an awesome machine but the placement of the motor is detrimental to its longevity. The air intake sucks in so much debris inherent in the walker design with its suction blower it can't help itself from self destruction. I do have a few friends that have replaced a few engines on theirs. They love them for leaf cleanups.
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
Ford 4x4 Pickup Truck Bed (A49461)
Ford 4x4 Pickup...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
