monster318
Hello. I was gifted a Scag Super Z with a 22hp Kohler command engine that had a cylinder 1 blown head gasket. (Was burning oil very badly). So as a precaution I put a whole new head with all new valve train on that side. Also as a precaution I removed the valve cover from the cylinder 2 side and looked everything over including taking the rocker arms off. When I deemed everything on that side visually appeared okay I went to put the rockers back on. On the exhaust side the bolt stripped out of the head that holds the rocker down. So I put a Heli coil on both the intake and exhaust rocker bolt. Reassembled everything and thought we were good to go. Once I got the motor running everything was fine. The very first time I mowed with it, on the second pass maybe about 15 minutes into mowing it POPed and after some investigating I found exhaust rocker on cylinder 2 broken in half. I had an extra on hand from the cylinder 1 side that I had replaced. So I installed that. Now after about 2.5 more hours on the clock it broke that same rocker again in the same way.
The motor doesn't knock or tick or anything it shows no sign before it breaks it just goes POP and that's all she wrote.
What could be causing this??
