komatsu left steering clutch problem
   / komatsu left steering clutch problem #1
DeArmond
greenville ky
komatsu d20p,IH706,caseIh459,mahindra 4500
when operating on a flat plane clutch wont work , but when you nose the trator down hill clucth work like a charm is this a clucth, break, or a linkage problem?
   / komatsu left steering clutch problem #2
Since the clutches are disengaged by applying pressurised oil, im wondering if you are just low on hyd oil.
   / komatsu left steering clutch problem #3
Thats what it sounds like to me too but I'm confused why it should just be the left side
this one is a old straight shift tractor ,left clucth paddle two hand controls for steering right paddle breake the right clucth works but makes nose like its breake needs adj . my dozer is a d20p-5 s/n 45001 and up range (an old rice patty special)
   / komatsu left steering clutch problem #5
You got me stumped there. I only have experience with powershift wet clutch models and newer. Sorry i cant help ya.
   / komatsu left steering clutch problem #6
If you haven't already I'd try to adjust the steering clutch on that side. At the rear of the dozer (on my d20p6) there are removable plates with a 17mm adjustment bolt under it. It can be hard to move if not adjusted in a long time. Bring a breaker bar and wd40 just in case.
thanks boys wil-do
NEW HOLLAND TN75SA TRACTOR (A51247)
NEW HOLLAND TN75SA...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
(1) RYOBI 212CC GENERATOR (A51248)
(1) RYOBI 212CC...
EZ GO EXPRESS S4 EFI GAS GOLFCART (A51247)
EZ GO EXPRESS S4...
2004 TerraGator 8104 (A53472)
2004 TerraGator...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
