Koyker 210 Cylinder Leaks
   / Koyker 210 Cylinder Leaks #1
JSedalia
Anyone else found the piston seal kits to fail frequently? Also, the gland "nut" is made from aluminum, and the threads steel. Doesn't bode well when trying to loosen a very tight gland assembly. Strips very easily.
   / Koyker 210 Cylinder Leaks #2
I have a 210 with 2 1/2" cylinders. The only leaks I have seen were from the crimps on the hoses. They were replaced under warranty. Other than that they are dry as a bone.
Gary
   / Koyker 210 Cylinder Leaks #3
I am a Koyker dealer and sell the loaders installed on Jinma tractors and drop ship them to be installed on other brands of tractors.
I have not had any cylinder problems as of yet. Don't know how old yours is but maybe your dealer can help you ??
Ronald
Ranch Hand Supply
   / Koyker 210 Cylinder Leaks #4
I have a Koyker 155 and going on my 2nd set of piston seals in the bucket cylinders in 6 years. My dealer told me that I would only get about 3 years out of them and so far he's close. I do work it hard commercially. I also found just putting a little heat on the packing nut end of the cylinder and the packing nut "gland" will come out very easy.
Dave
Thanks for weighing in! With a little help from my mechanic, he was able to free the stuck gland. Have parts but the threads on the cylinder sustained just enough damage to prevent putting humpty back together again last night. Now will be finding someone to square the threads away again. Hopefully won't need new cylinder.
Don't mind the fact that the seals and stuff wear out, its the surrounding quality of stuff that prevents the shade-tree tractor mechanic from getting it all apart and back together frustrating. Like the 1 6.8345/8 size wrench you need that nobody makes to get the gland off.
Thanks for the tips.
2017 Chevrolet Silverado 3500 HD Crew Cab KUV Enclosed Service Truck (A52377)
2017 Chevrolet...
2005 Texas Bragg T/A Gooseneck Trailer (A53117)
2005 Texas Bragg...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
1996 STOUGHTON TRAILER DRYVAN (A53843)
1996 STOUGHTON...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
