Kubiota M7040SUDH hydraulic pump
   / Kubiota M7040SUDH hydraulic pump #1
waggy5
New York
Kubota M7040 & B2320
Hi, does anybody know how to modify a Kubota M7040SUDH tractor's hydraulic system, specifically the hydraulic pump? the existing 11 gpm pump if far from adequate! the 3pt lift and loader just does not cut it. Thanks!
   / Kubiota M7040SUDH hydraulic pump #2
Maybe your tractor is not feeling well. You have a 5,000 lb tractor that should lift 3,300 (at 24") on the 3pt and 2,900 (at the pins) on the FEL. Considering the basic weight and footprint of the tractor, many people would consider those specs to be adequate for a small ag utility tractor and from what I can see, the other big manufacturers (Deere, NH, Case-IH, to name a few), are pretty much in line with that on their 70-75 hp utilities. Their implement pumps are also in the 10-12 gpm range. If you need to lift 5,000 lbs on the 3 pt, for example, I think you need more tractor than a 75 hp utility.
   / Kubiota M7040SUDH hydraulic pump #3
How is it not cutting ir¿
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A53426)
2016 KENWORTH T680...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
HOBBS MODEL-666 16' HAY RAKE (A51247)
HOBBS MODEL-666...
ECHO CS-3510 CHAIN SAW (A51248)
ECHO CS-3510 CHAIN...
2006 Kubota L3130 (A50123)
2006 Kubota L3130...
