Kubot rtv900 w/900 hours flamed out...
   / Kubot rtv900 w/900 hours flamed out... #1
gjd52
livonia, mi
kubota rtv900
Hello out there,
This summer my 900 became hard to start then just flat out won't! Realized that the fuel was years old and disconnected the fuel filter to drain the tank. Refilled with fresh fuel but still no start. Disconnected the fuel filter from the tank and ran the starter-no fuel being pushed through the filter. The fuel will drain out slowly through the filter with gravity doing the chore.
While cranking should the fuel be pumping out of through the disconnected fuel filter? Is there a fuel pump somewhere or is the injector the fuel pump?
Thanks for any tips on this.
gj.
   / Kubot rtv900 w/900 hours flamed out... #2
Yes, there is a fuel pump and yes you have to bleed the fuel injector lines when you disconnect the fuel filter and allow air into the system..........do a search for bleeding the injectors. It's a simple task and several videos are available when you do a search.........God bless.........Dennis
Thanks for the quick reply Dennis. Since there is a fuel pump and no fuel is coming through the disconnected filter when the starter is engaged it sounds like the pump is bad. Is the pump in the tank?
gj.
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
Deere 331G (A50123)
Deere 331G (A50123)
