Comparison kubota 161 or Takuechi 145
   / kubota 161 or Takuechi 145 #1
BTS44
Help me! Which is better? Takuechi 145 or Kubota 161??
   / kubota 161 or Takuechi 145 #2
I think you have picked the two leaders there - our local hire shop does Kubota - but says the only reason they do not do Takeuchi is that the local dealer is also a rival in hire industry.
Just to confuse - do not forget Kubota's zero-tailswing U50.
I guess in your shoes I would look at quality of dealership as an important consideration.
I might also look at upgrade plans - I am not sure the Takeuchi may be due for a new model soon as the 135 seems to be upgraded to a 235 although the 125 and 145 are still current. Just a thought.
Edit: Just seen that there is now the TB250 - http://www.takeuchi-mfg.co.uk/NewTB250.htm - but that may mean the TB145 will be cheaper!!!!
J
   / kubota 161 or Takuechi 145 #3
I've not seen a single TakEuchi dealership but many kubota
I have no experience with either macHines but if i were to purchase an excavator I'd go with the one that I can most readily Available parts and support
Joel
Yes I know the Kubota is a zero turn, but why wouldnt every one buy a zero turn they cost the same?
Are there any disadvantages with the zero swing?
   / kubota 161 or Takuechi 145 #5
Sometimes zero tail swing is achieved, in part, by widening the tracks making a ZTS digger less manoeverable.
Also, on principals of leverage - there are two things to achieve a counter-balance for the boom - one is to put a weight further from the centre (fulcrum) such as on a non-ZTS digger - the other is to put heavier weight nearer the centre such as on a ZTS.
So a ZTS digger may be wider and heavier than a non-ZTS of same capability.
J
Thank you for the info. So if I will be digging in tight areas the weight is a trade of for the zero turn. They will dig about the same?
Sorry if its a dumb question
   / kubota 161 or Takuechi 145 #7
There is a newer version of the KX161 that just came out, its a K050. There is also a zero tail swing model thats the U55. We just got our first ones two weeks ago.
JMR Attachments Tree Boom (A50121)
JMR Attachments...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
