Kubota 2660 Engine RPM's
   / Kubota 2660 Engine RPM's #1
Popfizz7
Southern Indiana
John Deere 2032R
Hello everyone. I am new here so I apologize if I posted this in the wrong thread....
But I just bought a new 2660, FEL and 60' deck. My questions are..... what is the normal idle speed for this tractor? Mine idles at approx 1350 rpm. Also, what is the maximum rpm? I know the maximum rated rpm in the owners manual says 3200 but mine will rev all the way to 3450 at WOT. Is this ok?
Thanks in advance,
Popfizz7
   / Kubota 2660 Engine RPM's #2
The manual on my machine specifically states not to run WOT for the first 50 hours, so keep that in mind. I have been keeping mine at about 2900 when working and it does not bog, and will run it that way until broken in.
I have revved mine to over 3300 for a second in neutral, but in gear at WOT it runs at 3200. I wouldnt worry a whole lot about it now because you should not be at WOT anyways, but it would be worth a call to your dealer to make sure the governor or fuel pump is not slightly out of adjustment
   / Kubota 2660 Engine RPM's #3
Welcome Popfizz! I know you'll get the help you need. Enjoy!
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
378808 (A51573)
378808 (A51573)
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
