jardine121
First of all, please excuse my ignorance, I am by no means a mechanic. Nor do I know a whole lot about tractors (yet). We have a Kubota 6030DT 58 horse built around 1990.
My wife plowed our driveway about a week ago and things were fine. 2 days ago, it got pretty cold (8f at night, 15f day), snowed some more, and the tractor started rough, she drove it a short distance (by our horse barn, maybe 100 yards) and turned it off to go do something else. She hopped back on and it then refused to start (it turned over slowly, but didn't even begin to fire). Upon my father-in-law's advice, we put some additive in the fuel, she put new diesel in as well (there was some summer diesel in there), I bled the lines, we put a battery charger on it (ran it out of juice trying to start it earlier). Then we put a small propane heater to warm up the block/fuel lines as we thought maybe the fuel had gelled up. After about 90 minutes of heating (we also plugged in the block heater) we went to start and it wouldn't start. (It was turning over faster though, so it appears the propane did help loosen the oil up.) I then sprayed some starter fluid in the air intake as she cranked the ignition, and it started right up. We disconnected the battery charger, let it idle, and 5 minutes later it died. She could not immediately start it back up - it turned over, and was trying to start, but just couldn't quite make it. I again sprayed some more starter in the intake, and it still wouldn't start. So I put the battery charger back on, switched to 100 amps, she cranked as I sprayed starter fluid and it started up again. Like the previous attempt, it seemed to run fine for 5 minutes then it just died. No sputtering or anything, just went from OK to dead. We did this 2 more times with the same results. The last 2 times she drove it around (not too far from our outlets), and it seemed to run just fine, the poof - dead in 5 minutes. There was seemingly a pattern with the battery charger in that it seemed to only start with that connected (even though it cranked over just fine without it) I wonder if perhaps the alternator isn't working properly? Any suggestions?
