kubota 8200 hydraulic problem
/ kubota 8200 hydraulic problem #1
starcraft1976
vermilion ohio
kubota b8200
i just bought a 1986 kubota b8200 it had a bearing and oil seal bad in the transmission ,most of the hydraulic oil had leaked out. i replaced the bearing and seal, cleaned out the transmission and filter.got it all back together and it worked great, the three point lifted smooth with no noise for a couple of hours then it stopped lifting.now it comes and go's sometimes it lifts and sometimes it don't.anybody got any ideas. thanks alot
/ kubota 8200 hydraulic problem #2
Airlock???? Don't know how to bleed, but that is where I would be looking... Good luck and let us know. Hopefully you will get a better answer.
John Deere 608C 6 Row Corn Head (A64119)
John Deere 608C 6...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
generator trailer (A61569)
generator trailer...
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
Schulte Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte Batwing...
