Kubota B1640 FEL Control Valve Replacement?
   / Kubota B1640 FEL Control Valve Replacement? #1
ghout7
Michigan
Kubota L4701
Hi,
New to the forum, and new to tractor ownership, so sorry for the stupidity! I recently bought a Kubota B7200 tractor with a backhoe and B1640 Front End Loader from my brother, with the knowledge that it needs some "work".
The control valve for the FEL is most likely shot, and I think I'd rather replace it than rebuild it. It sprays out a steady stream of oil on my feet at certain times, and gets stuck in the up position often.
The problem is that I'm having difficulty finding specs, and I know next to nothing about hydraulics. I've attached a diagram of the existing control valve from the user manual, and am wondering if anyone can suggest a source for a replacement that would work.
The manual only states "control valve, two spool with handle" and the specs say "one detent float position, power beyond circuit" and relief valve setting at 1450psi.
Any suggestions would be greatly appreciated!
Greg
   / Kubota B1640 FEL Control Valve Replacement? #2
I just replied to your other thread-Please do not post the same question in multiple forums, it make it VERY hard to help you when info is spread a crossed different post's.
Eager Beaver (A50322)
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
RoGator RG1100C (A52128)
RoGator RG1100C...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
