Kubota B6000 Doesn't Crank Fast Enough to Start
   / Kubota B6000 Doesn't Crank Fast Enough to Start #1
hobie
Massachusetts
Jazee One
I neglected to put a trickle charger on my tractor for a couple of winters with very light usage during the year. When I put a charger on it this spring, it wouldn't crank fast enough to start. I have had this problem last fall, but put jumper cables on and it started right up. Today a friend was trying to start it with jumper cables, and it still would not crank fast enough to start. Any ideas? Any help much appreciated. Thanks
   / Kubota B6000 Doesn't Crank Fast Enough to Start #2
Once a battery is drained down enough to make cranking over your engine fast enough to start the tractor impossible, just jump starting will not work. You need to either replace the battery, or have it load tested, AFTER it has been charged by a regular charger long enough to bring it up to full, or as close to full charge as possible. Then, when it has an induced load placed on it, it will either pass or fail the test. Fail indicates new battery time. Pass means you can reinstall it and get whatever life is left out of it.
Batteries need to be kept at 80% charge and up. Once one lets a battery sit, without using the machine it is installed in for long periods of no use the cells start to sulfate. a TRICKLE CHARGE IS NOT ENOUGH TO DESTROY THE SULFATION, HANCE YOUR NO START CONDITION. (Sorry, caps mishap).
A battery tender, or using a battery isolation switch to 'disconnect' the battery from the tractor without removing it, could keep the same situation from repeating.
However I suspect you will need a new battery since you've been killing yours for some time now.
And while it's out, before installing one, same or new, clean up the ground at the frame and both post connectors until they are all shiny metal. Then coat the chassis/frame ground with battery protector spray, and do the same at the posts. I also use the anti-corrosion felt washers to help reduce oxidation/corrosion.
If you still have starting issues it's time to cut back the plastic insulation jacket at the frame ground of the negative cable, and see if there is presence of corrosion under the jacket. Is so, or presence of same on the positive cable, less common but not totally unusual, then replace either cable showing corrosion. With the positive cable make sure the battery is disconnected at the ground post (negative side) of the battery before cutting back the jacket.
Post back results.
Thank you for such a complete explanation. I'll have to find a new battery.
   / Kubota B6000 Doesn't Crank Fast Enough to Start #4
You're welcome. Try to get an Interstate brand. I used to sell them in my foreign auto shop.
Also, get yourself a Battery Tender to replace the trickle charger, and as I mentioned a battery isolation switch which goes on the ground side post of the battery. If it will sit unattended for long time during the winter take the battery out and charge it someplace indoors within a heated area, instead of the cold wherever it is now. Do NOT place it where an open flame for a boiler or gas fired water tank resides!
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
74in FEL HD Round Back Bucket (A51039)
74in FEL HD Round...
2003 Ford F-450 Knapheide Enclosed Service Truck (A48081)
2003 Ford F-450...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
