Kubota B6100 ignition switch question
   / Kubota B6100 ignition switch question #1
txdave05
I broke the key of in my ignition switch, and I was just replacing it with a universal switch and a seperate glow plug button. Anyway, I had 5 terminals on the old switch:
1) Power in
2) Start
3) Run (hour meter, lights, horn)
4) Glow plug
5) ???????
It's a black wire with a white stripe, it has 10 Ohm between it and the ground side of the battery, and I can't for the life of me figure out what it does. Everything seems to work without it hooked up. Any ideas what it is?
   / Kubota B6100 ignition switch question #2
When I traded in my B6100E I kept the manuals. If I get time tomorrow I will look to see if there was a schematic in them. I think that there was.
Vernon
The circuits listed on the back of the key switch are 17, 19, 30, 50, AC.
I can't remember which wire came off which terminal. Hope that helps. Thanks in Advance.
David
   / Kubota B6100 ignition switch question #4
I think AC would mean accessory.
2018 Ford E-350 Super Duty Knapheide Service Van (A44571)
2018 Ford E-350...
John Deere 7300 MaxEmerge 2 4-Row Planter  Adjustable Row Spacing (A46877)
John Deere 7300...
2012 International DuraStar 4300 Altec LRV60-E70 70ft Bucket Truck (A44571)
2012 International...
2005 Ford F-350 4x4 Pickup Truck, VIN # 1FTWW31P15EB55494 (A44391)
2005 Ford F-350...
2012 MACK GU713 TRI AXLE DUMPTRUCK (A43004)
2012 MACK GU713...
2009 INTERNATIONAL DUMP TRUCK (A43004)
2009 INTERNATIONAL...
