3-Point Hitch Kubota B7100 HST remote hydraulics?
   / Kubota B7100 HST remote hydraulics? #1
Knucklehead11
boyne city, MI
Terex PT-80, JD 7775, Skytrack 6042, Kubota B7100, Genie Z45, MEC 3072
My B7100 HST is equipped with a hydraulic diverter valve to switch the hydraulic flow from the internal 3-point hitch cylinder to an external use. My question: is this port live or is it controlled by the three-point control valve? Also, the manual makes mention of a return port, but I am unable find where this is located. I would like to use this for a single acting cylinder on a dump trailer. Any ideas?
   / Kubota B7100 HST remote hydraulics? #2
Your hyd pump feeda a hyd block and then feeds the 3pt.
If you want a valve to operate a SA cyl. you would use a DA valve or a SA valve and use the hyd block ports and then plug the A port on the DA remote valve
   / Kubota B7100 HST remote hydraulics? #3
You need an adapter plate with threaded ports on the hyd block to replace the blank adapter plate.
The valve should have a PB port.
2020 Toyota Tundra Pickup Truck, VIN # 5TFEY5F14LX266984 (A44391)
2020 Toyota Tundra...
Ditch Witch DP-190 Packer (A44391)
Ditch Witch DP-190...
2007 GMC C7500 24FT NON CDL BOX TRUCK (A43003)
2007 GMC C7500...
2025 9ft Office Shipping Container (A44571)
2025 9ft Office...
2022 John Deere HPX615E Gator 4x4 Utility Cart (A44572)
2022 John Deere...
Kivel 48in Forks and Frame Skid Steer Attachment (A44571)
Kivel 48in Forks...
