Kubota b7100 HST will not stop when releasing pedal
   / Kubota b7100 HST will not stop when releasing pedal #1
bluegold
Port Saint Lucie FL
Cu Cadet LT2042
My Kubota B7100 HST does not stop when releasing the pedal when going forward, I have to push the reverse pedal to make it stop. In reverse it stops as soon as the pedal is released. Is there an adjustment for the forward issue?
Thank you
   / Kubota b7100 HST will not stop when releasing pedal #2
There is a v plate under the floorboards that a roller fits in for forward neutral reverse positions. The roller is on a spring tensioned lever. Check out the mechanism for proper alignment and tensioning. In neutral the roller should be at the bottom of the v. There is also a micro adjustment screw behind a plug on the side frame.
   / Kubota b7100 HST will not stop when releasing pedal #3
Also keep well grease.
Thank you for the reply. I finished cleaning the linkage and will make the adjustments you have recommended.
Thanks again
   / Kubota b7100 HST will not stop when releasing pedal #5
Trace the entire linkage and lubricate it. There is also a damper, which is meant to slow the return to center, and it can sometimes stick too.
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Polaris Ranger (A56859)
Polaris Ranger...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2013 CATERPILLAR 308E CR EXCAVATOR (A60429)
2013 CATERPILLAR...
2016 FORD TRANSIT 350 CARGO VAN (A59905)
2016 FORD TRANSIT...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
