KUBOTA B7100 HYDRAULIC LEAK
   / KUBOTA B7100 HYDRAULIC LEAK #1
Anonymous Poster
Epic Contributor
I RECENTLEY REPLACED A PTO SEAL ON THIS TRACTOR. THE LEAK HAS STOPED, BUT WE ARE HAVING TROUBLE BLEEDING THE LINE OUT. WE ARE NOT SURE EXACTLY HOW TO DO THIS. CAN SOME ONE HELP? THANKS.
   / KUBOTA B7100 HYDRAULIC LEAK #2
How about a little more information. There are no hydraulic lines connected to the PTO shaft, but the hydraulic pump pulls fluid from this cavity. Did you drain the hydraulic fluid when you worked on the pto seal and now have air in the hydraulic lines? If so be sure that you replaced the hydraulic fluid with an approved UDT or Super UDT fluid as required and that you added the correct amount of new fluid. Did you replace the hydraulic filter (if it has one) and clean the hydraulic screen (if it has one). I would normally start the tractor and slowly move the loader or other hydraulic implement including 3 point slowly through the range of operation several times and that will normally clean out any air that got in them. If you collaspse all cylinders when you drain them, then there is little room for air in the first place.
2024 KMC 7406 (A53084)
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
Misc. Dell Docking Stations and Keyboards (A50325)
Misc. Dell Docking...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2008 Chevrolet Impala 50th Anniversary Sedan (A51694)
2008 Chevrolet...
2020 KUBOTA RTV...
