Kubota b7100 hydraulics very slow
   / Kubota b7100 hydraulics very slow #1
double hunter
Ford 1715
I have a buddy who has a Kubota B7100, 4wd, fel, runs great but the hydraulics are in slooow motion, what are some of the things we can check, thanks for any help.
   / Kubota b7100 hydraulics very slow #2
Filters. Which hyd , drive hyd, or implement hyd such as loader, 3pt, etc.
Install a pressure age and monitor the pressure and report back. Maybe the pump is worn, and is pumping less than advertised, with low pressure.
A relief valve could be held open by debris/trash.
If you take your tractor by the dealer, and have them do a flow and pressure test, they can give you an informed idea what may be wrong.
Check that the 3pt lever is not all the way up, and keeping the system in relief.
   / Kubota b7100 hydraulics very slow #3
Check the position of the three point control lever.:)
   / Kubota b7100 hydraulics very slow #4
If it's the 3pt lever then your feedback rod needs adjusted.
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
JOHN DEERE 5 BOTTOM PLOW (A52708)
JOHN DEERE 5...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
