Kubota B7200 hydraulic Pump Rebuild
   / Kubota B7200 hydraulic Pump Rebuild #1
GE222
Northern Illinois
Has anyone ever rebuilt a hydraulic pump on a Kubota B7200 with a geared transmission. Thought I would ask. I have yet to do much research, as I am only near the tractor about once a month.
It is all I can do to get the 3-point arms to raise, on a warm day. The arms won't raise at idle, but will very very slowly at a higher engine RPM. Once up, the valving will hold a load just fine. The suction line screen has been cleaned, and the fluid has been changed with new Kubota trans fluid ($$). No, I don't have a pressure test gauge, yet.:confused:
   / Kubota B7200 hydraulic Pump Rebuild #2
The only parts available for the pump from Kubota are the o rings and seals in the pump, if the gears or pump wall is worn a replacement pump will be needed.
When the screen was clened was there contaminates in the filter?
I cleaned it last summer. I did remember some small metal particles, which didn't surprise me too much. The quantity was such that I probably had reduced flow, but not completely plugged.
As I recall the pump seemed to be easily accessible.
   / Kubota B7200 hydraulic Pump Rebuild #4
Try leaving the suction strainer out and see what happens. My brother has an Allis-Chalmers 5040 with the same exact symptoms. Suction strainer looked fine. Cleaned it, no help. Ruled out everything else, then finally left the strainer out and everything worked great. Installed a new strainer, no problems.
That sound like a good idea to try. The drawback is loosing fluid. I don't like to drain fluid and re-use it. Tipping the tractor helps not to loose so much. The fluid is new; however, I suppose I could filter it prior to re-using it. If I get a chance, I will try go buy some this weekend.
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
2020 CAT 239D3 Skid Steer (A51573)
2020 CAT 239D3...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2024 KMC 7406 (A53084)
