Kubota B8200 ... Where is tran/diff drain plug?
   / Kubota B8200 ... Where is tran/diff drain plug? #1
ybk1935
I have recently purchased a Kubota b8200e (two wheel drive). I have started changing fluids, and I don't see an easily recognizable drain for the tran/dif/lift unit. I know it takes udt transmission fluid, but I don't know how much or where to drain out the old fluid. Any help on this will be most appreciated. Thanks
ybk1935
   / Kubota B8200 ... Where is tran/diff drain plug? #2
This is just a guess as I'm not familiar with the B8200 (I have a B7100)
Take a look under the tractor at the rear where the axles exit the main body casting. On the B7100 there is a drain plug on each side at the lowest point which drains the entire hydraulic/lube reservoir.
Hope that helps until a better reply comes along.
Sherweld
Hi
Thanks for the information on the b7100. I did a more detailed search after your pointer and found the drain. Its at the rear of the diff and hidden by the drawbar plates. I may be able to get it out without taking down the drawbar, but it doesn't look promising.
Thanks again
ken moreau
2019 John Deere 6175M (A50120)
2019 John Deere...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
Grundfos Centrifugal Pump (A50121)
Grundfos...
7' x 7' Steel Frame Cover Hut (A50121)
7' x 7' Steel...
2005 East Manufacturing 45ft T/A Walking Floor Trailer (A50323)
2005 East...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
