Backhoe Kubota backhoe to ford 1210 tractor
   / Kubota backhoe to ford 1210 tractor #1
ford 1210 - ford 821
I'm trying to attach a kubota backhoe to my 1210 ford tractor and i'm not sure where to hook up the two main lines. I tried hooking to the same place that the front loader hooks by "T"ing in but when all hooked up nothing works. I am using the same two lines that the previouse owner used but I noticed that there is another line with a cap on it ???????. The ford owners manual is vage at best. Please help me I need this little machine to work for me.
   / Kubota backhoe to ford 1210 tractor #2
If your tractor has "open center" hydraulics (I cannot find whether it does or not), you cannot have a tee fitting; the system works by "stopping up" a constant flow of hydraulic fluid to create pressure. An "open center" valve may have (besides the ports to go to cylinders or motors) an input, a drain to tank, and sometimes a "power beyond" port, so that you can attach that to another valve in series with the other.
First, find out your type of hydraulic system, then it should be easy to work from there.
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2000 MERCEDES-BENZ S-Class (A50324)
2000 MERCEDES-BENZ...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
