Kubota BX2200 - smoking...
   / Kubota BX2200 - smoking... #1
Sedge1
Bangor Maine
Kubota BX2200
Friends, while mowing today, white smoke wafted out from under the hood. It was about an hour or so into the mow. About 3 minutes after I first fired it up at the beginning of the mow, it just conked out, which it has never done. It started up with no issue, but did it again about 10 minutes in. then the smoke happened about an hour later. The gauge all read normal. The temp was in the normal range, and the engine ran fine, with no roughness, until it didn't. There was a slight buring smell, but nothing powerful. I did not try turning it on after the smoking event. I should mention that I did clean the interior filter screen, and cowl before the mow.
So are there any things that I, as a non-mechanic can do to try to eliminate possible causes before calling my local daer and spending the $$$.
Thanks for the help.
David
   / Kubota BX2200 - smoking... #2
I believe you need some dealer interventio9n and I know your local dealer. They are good people.
   / Kubota BX2200 - smoking... #3
Fuel filters are a common problem on BX’s, but your symptoms don’t seem to match that. Usually the tractor loses power and stutters.
   / Kubota BX2200 - smoking... #4
After it cools down, open the hood and look around to see if you can see what may have burned. Possibly some wiring. Could be something simple (but usually not) - worth it to at least look around first.
   / Kubota BX2200 - smoking... #5
David
You say from under the hood and not the exhaust. I would look around for something burnt like seville009 says. Perhaps a wire that is shorting out or you may have inadvertently bumped something while you were in there cleaning the filter?
2023 New Holland C332 Two Speed Compact Track Loader Skid Steer (A45336)
2023 New Holland...
12in Backhoe Bucket (A48561)
12in Backhoe...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A43476)
Heavy Duty Skid...
2002 Peterbilt 378 T/A Road Tractor (A43476)
2002 Peterbilt 378...
2024 DISCOUNT DUMP TRAILER (A45677)
2024 DISCOUNT DUMP...
Skidloader Trailer Mover (A47809)
Skidloader Trailer...
