kubota bx25d front wheel drive only
   / kubota bx25d front wheel drive only #1
Robertlhan
Rockport
2012 kubota bx25d
Iv got a 2012 kubota bx25d,and was out plowing with it,pushed in the diff lock,hit reverse and now i have no rear wheel drive,checked the tires spinning in the rim,because thats happened before but both wheels are turning,just no power to the rear wheels,checked the fluids,levers and all that,but will only move the front wheels,Any help would be great,thanks
   / kubota bx25d front wheel drive only #2
There is a history on the BX of the diff lock pin failing and taking out the rear axle. The potential is great that you have experienced this unfortunate phenomenon.
I've given you some links, there are plenty more. Google BX25 diff lock failure and you can follow that down the rabbit hole. I did include a YouTube video link of a repair...
http://www.tractorbynet.com/forums/kubota-owning-operating/227085-bx24-diff-lock-disaster-how.html
http://www.tractorbynet.com/forums/kubota-owning-operating/379404-bx25-differential-lock-problem-need.html
Kubota BX25 differential lock fail and repair This is the BAD news. - YouTube
PT 1000 Gal Sprayer (A44501)
PT 1000 Gal...
JCB 509-42 Telehandler: Non-Running (A42203)
JCB 509-42...
500 Gal Fuel Tank w/Pump (A44502)
500 Gal Fuel Tank...
New/Unused 12X20 Steel Carport (A44391)
New/Unused 12X20...
2009 Tennant 810 Sweeper (A45336)
2009 Tennant 810...
2018 Bomag BMP 8500 Trench Compactor (A44391)
2018 Bomag BMP...
