Kubota changing front AG/R1 tires from 6 to 4 ply?
   / Kubota changing front AG/R1 tires from 6 to 4 ply? #1
OrangeAlex
NW Oregon
Kubota L3130
Hello,
It seems that Kubota has decided to replace the 6 ply AG/R1 front tires found on some L/GL tractors with 4 ply tires. I was lucky enough to have the 6 ply put on (my L3130) because my dealer has inventory but I am told that the new front tires they are delivering are 4 ply. Rears have not changed, they were 4 ply and are staying that way. They were 6 in front/ 4 in back. Now going to be 4 in front and back? Anyone one know if this is true that can confirm or deny? Are they trying to save some costs here? Putting 4 ply fronts on something like an Grand L with its strong front loader seems like a mistake.
-Alex
   / Kubota changing front AG/R1 tires from 6 to 4 ply? #2
How do you like it? Did you get a backhoe and soft cab?
do I like it or not? I guess my answer would be a bit biased so I wont bother generating a response ;-)
My machine is mostly used in the woods to clear brush. So I did not need or want a cab. I really wanted the BH90 backhoe but could not justify it for $7500. My use for it would be occasional mostly stump removal and light trenching. Instead, I got a Markham Welding Grubber bucket for the FEL for around $350 to do this work. Think of it as a shovel for the FEL. About 14" wide in front with 3 teeth, and tappers out towards the back. About 3 feet deep. For jobs where I need to do serious digging, which does not happen often, I will just rent an excavator. $7000 savings will go a long way.
   / Kubota changing front AG/R1 tires from 6 to 4 ply? #4
I bought a L3130 in November 2004 and it has 4 ply front and rear tires. The manual says it has 6 ply front tires????? It doesn't. I guess Kubota is still making the same $$$ and paying less for the tires. More profit is what it sounds like.
I keep my tires at maximum pressure because when I lift a heavy load with the loader the front tires look almost flat. When the tires wear out I will replace them with better tires. /forums/images/graemlins/grin.gif
Curt
   / Kubota changing front AG/R1 tires from 6 to 4 ply? #5
It's all about the money. Yet I will tell you 4 ply tires are good also.
It is in the dealer spec books. They used to use Goodyear's in front which are 6 ply. Firestone in back which are 4. This was done explicately because of the strong front loader.
   / Kubota changing front AG/R1 tires from 6 to 4 ply? #7
I just got my L3400 and it has the 6 ply Goodyears on the front (Ag tires).
2015 Ford E350 Cutaway Van (A52377)
2015 Ford E350...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2001 MACK RD688S (A52472)
2001 MACK RD688S...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2008 JACK  130BBL (A52472)
2008 JACK 130BBL...
