artfull dodger
We own a early 80's Cub Cadet 782d tractor, powered by a Kubota D600 diesel engine. It has never sounded quite right when it ran, smoked way to much and lacked the power of other 782d's. Finaly toward the end of the show/plow day season she started leaking fuel around the top of the injector pump on the middle and rear cylinder lines. This was from inside the pump and coming out around the oval plate with 2 special nuts on it in the one picture. Estimates to rebuild the pump were $300-$600 at the local shop. I found someone selling a brand new 3 cylinder injector pump on ebay, while it wasnt for the D600, she did have a new one for that model. Total cost was $312 delivered. Changing out the pump is pretty straight forward. Make sure everything is real clean, which ours is kept this way all the time. Remove the intake from the side of the block, remove injector lines, fuel return line, and the 4 allen head cap screws from the pump. At this point you can lift the pump out of the engine block. Take note of how many shims if any there are, you will need to remove the shim from the old pump and install on the new one to maintain proper injection timing. On the top side of the pump is a slide shaft with a knob on it, this is the fuel rack control, it just slides into a slot on a linkage that is just inside the engine block. After bleeding the fuel system, she fired right up, with the correct sound to her now, lots of power and much less smoke under a load, most of which was from it being quite cold out. Now we have a spare pump that is bad, maybe I can find a vo-tech school that trains on injector pump rebuilding and get it redone cheaply someday. Cheers Mike and Michele
