Oil & Fuel Kubota engine Injection pump won't deliver on #1. Rotated delivery valve housing
   / Kubota engine Injection pump won't deliver on #1. Rotated delivery valve housing #1
ccaissie
Lincoln county, Maine
International B275
Yep, the bracket that holds the injection delivery valve housings for #1,2 was evidently loose, so when I removed or installed the line (head replacement), I rotated the delivery valve housing. Evidently I turned it far enough to get it out of the pumping stroke and it's not putting out any fuel.
So, how to restore this setting? Trial and error? Look for paint/contact marks indicating where it was?
I warmed the engine up on 3 cylinders and will be retorquing the head, changing the oil again, and other stuff, but It would be nice to get this unit running on all 4.
T-190 Bobcat with V2003T engine.
   / Kubota engine Injection pump won't deliver on #1. Rotated delivery valve housing #2
On that particular mdl pump, if the top nut comes loose, the barrel that controls the amount of fuel, turns..
THATS WHY it has that bar across the top nuts.. {delivery valve holder}
If u email me at my home address, I'll help u out.. TPG
   / Kubota engine Injection pump won't deliver on #1. Rotated delivery valve housing #3
We are having an issue with a delivery valve out of adjustment as well. Can you help?
   / Kubota engine Injection pump won't deliver on #1. Rotated delivery valve housing #4
Yes..
Did u have a hand in it getting out of adjustment??
U can contact me directly at:
My screen name at aoldotcom in your mail service..
2002 Gene 12ft T/A Utility Trailer (A46683)
2002 Gene 12ft T/A...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A46684)
2017 Ford F-150...
2014 Dodge Journey Value PKG (A46684)
2014 Dodge Journey...
H&S Silage Wagon (A49251)
H&S Silage Wagon...
2005 International 4300 Heil Dump Truck (A46683)
2005 International...
12-16.5 Tires on Wheels (A49251)
12-16.5 Tires on...
