Kubota Factory BH 92 Hydraulic Thumb Cylinder Dimensions
   / Kubota Factory BH 92 Hydraulic Thumb Cylinder Dimensions #1
paulwestski
VA Beach & Amherst, VA
Kubota L4240
I need some measurements please.
Someone with a factory Kubota BH92 hydraulic thumb, could you please measure the hydraulic cylinder for me??
I currently have the mechanical thumb that I wish to convert to hydraulic.
So I'll need the cylinder diameter, overall length closed and overall length extended.
I may just have Fit-Rite weld one up for me rather than trying to procure one.
The hydraulic fittings on the factory cylinder are on separate sides to allow for the best hose routing.
   / Kubota Factory BH 92 Hydraulic Thumb Cylinder Dimensions #2
I have one but it's hibernating right now and not hooked to the tractor. So I can't flex the cylinder for measurements.
I'm not in any great hurry.
I am still figuring out what valve method I'll use.
WaxMan
Did that back hoe come out of hibernation yet?
   / Kubota Factory BH 92 Hydraulic Thumb Cylinder Dimensions #5
I forgot all about this thread and have missed your last post on it. Thank you for your PM reminder.
You are a very patience man when planing a project.
The BH 92 hydraulic thumb measures
41 1/2 from center of pin to pin open,
24 3/4 closed pin to pin.
1 1/4 piston diameter.
2 3/8 cylinder housing diameter.
Sorry I didn't get back to you sooner. Hopefully the one you have will work.
Let me know if you need anything else or need a picture of something. Good luck
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2008 FORD F-650 (A50854)
2008 FORD F-650...
Bus (A50323)
Bus (A50323)
71063 (A49346)
71063 (A49346)
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
