Kubota G1700
/ Kubota G1700 #1
hyper285
Hello
Anyone ever replaced a fan belt. What needs removing?Looks impossible Regards Chris
/ Kubota G1700 #2
Hello
If I recall, the G1700 is the same as the G1800 that I have, just a slightly smaller engine.
The belt is a PITA to replace. You need to remove the drive shaft that goes back to the HST, is it goes from the crankshaft back to the HST (through the pulley that the fan belt goes around).
/ Kubota G1700
Thank you for the reply -very helpful - looks like some work- presumably the body has to come off first so looks like a rotten job- Chris
/ Kubota G1700
Hi
well- not too bad. Remove mower deck,jack up, lie under from rhs,12mm spanner remove three bolts from lower pulley which separates drive, slip in belt, loosen alternator 12mm. PRZE IN BELT WITH SCREWDRIVER, APPLY TENSION TO ALTERNATOR AND RETIGHTEN Refit deck after greasing whilst off -tighten up 1/2 hour
Dont wash hands in kitchen sink as wife get agressive!-Chris
/ Kubota G1700 #5
Hi
Hello all, new to this site, looks very interesting. Does anyone have the part no. for the fan belt on the Kubota G1700 please.
Regards Dave
2011 International DuraStar 4300 Petersen TL3 Forestry Grapple Truck (A61568)
2011 International...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2025 QSJ Hydraulic Sweeper Mini Skid Steer Attachment (A61567)
2025 QSJ Hydraulic...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
