kubota g3200 won't start
   / kubota g3200 won't start #1
blackstone
My G3200 will not start or crank. The battery is good and shows no draw when attempting to crank engine. It actually can be started at the starter with a screwdriver but it will only run about five seconds. The electric fuel pump doesn't seem to be working either which makes me think that it is an electrical problem. It acts as if the battery is dead except that it can be started using a screwdriver. Has anyone had experience with a problem like this?
The seat safety is disconnected, where else should I check?
   / kubota g3200 won't start #5
I am not familiar with your particular tractor but if it has a HST with a rocker pedal try rocking it back and forth with the tractor brake locked and you in the seat hold the key in the start position and rock the pedal back and forth to each side of center. Sometimes the switch gets sticky or out of adjustment.
   / kubota g3200 won't start #6
I had a similar problem with G5200. Turned out to be a broken terminal in the wire harness. Trace wire harness out from switch to starter. Repair what you find as you go.
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
2007 TRANSCRAFT 48X102 FLATBED (A52472)
2007 TRANSCRAFT...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2012 RAM 5500 (A52472)
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2002 FREIGHTLINER FL60 SERVICE TRUCK (A52472)
2002 FREIGHTLINER...
