Kubota hydrodsatic abbreviations
   / Kubota hydrodsatic abbreviations #1
civilrider
Richmond, VA
I'm looking to purchase a used kubota B series and I'm getting confused on the variations of hydrostatic transmissions. I've seen the basic HST but also HSE and HSD. Can someone explain please.
Thanks,
John
   / Kubota hydrodsatic abbreviations #2
I think HSE stands for the 2WD version while HSD refers to the 4WD model. I haven't seen this distinction on the newer B series, only the older ones (i.e. B7100 HSE).
Thanks for the help. What you said makes good sense. yes I have been looking at older models...2400 and 1750.
Thanks again
   / Kubota hydrodsatic abbreviations #4
The other option you will see on the B series is HSDB which stands for hydrostatic transmission 4wd with bi-speed turn.
   / Kubota hydrodsatic abbreviations #5
As other posts have indicated, the "D" suffix indicates 4wd and the "E" suffix indicates 2wd.
For 4wd, you may see HSD or HST-D.
For 2wd, you may see HSE or HST-E.
For manual gear drive tractors, you may see the "D" or "E" suffix (such as B7100D or B7100E).
Hope this helps,
Kelvin
150 GALLON FUEL TANK (A51244)
150 GALLON FUEL...
2017 Ford Expedition SUV (A50324)
2017 Ford...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
1240 (A50490)
1240 (A50490)
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
