poppey
Hi
I have a second hand Kubota K0008 that was supposed to be from 2000. The belts are not adjustable so I have cut and welded in a square tube each side to widen it 300 mm (12 in). It has say about 2000 hr, it run well and is perfect for my use.
I is yellow today but original it has been light blue.
I have a parts manual with models from 2000 and it seems in general the same but itエs not. Air filter has a center bolt not two clips as in the manual. Filter is hollow in bot ends and measure L 175 mm (6.7 in) OD リ 83 mm (3.25 in) ID 46 mm (1.8 in). The one in the parts list is closed in one end.
Any one know something about this digger? And part no for the air/oil filter? Oil filter seems to be the one in the parts list. Engine is D722.
