kubota kx 121-3
   / kubota kx 121-3 #1
ANDY3882
wv
kubota l2600dt
i recently bought a 2003 kubota kx 121-3 to use during a house i am going to build. I noticed the upper roller on one side is making noise. How do you determine the condition of this roller and lower rollers. I spun it by hand and it felt gritty like a bad bearing but had no play. The track on this side is making a clanking noise from this roller the other track is quite. Also my tracks are at about 40% with tears and cracks in them and everyone i talked to says run them till they are smooth or break/split. Any advice on doing touch of painting on the rops gray on the undercarraige and counter weight.
   / kubota kx 121-3 #2
Congratulations on your purchase. You will get a lot of work done with it. The upper roller if it's making noise you can check to see if it has lube in it. If oil doesn't stay in because it's wiped the seal use a grease gun and pump grease in it IF you don't want to buy a new one. Good luck with everything and keep us posted.
Darin
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2014 Ford F-450...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2013 Chevrolet Sonic Sedan (A50324)
2013 Chevrolet...
2016 VOLVO EC300EL EXCAVATOR (A51242)
2016 VOLVO EC300EL...
2019 KUBOTA SVL65-2 SKID STEER (A51242)
2019 KUBOTA...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
