Kubota KX-91s has oil leak inside of track near the front under roller
   / Kubota KX-91s has oil leak inside of track near the front under roller #1
csharpe5097
NY
Kubota L4240
I have a 2006 kx-91s mini excavator. I noticed a black fluid inside of the front right track. I assume its oil but what is leaking and how do I fix it. Please
   / Kubota KX-91s has oil leak inside of track near the front under roller #2
Need to know more to help you. You only have the drive motor unless it is leaking from above.
What else do u need to know. It doesnt appear that any oil is coming from above. Just within the tracks
   / Kubota KX-91s has oil leak inside of track near the front under roller #4
   / Kubota KX-91s has oil leak inside of track near the front under roller #5
You need to determine if it's gear oil (real stinky) or hydraulic oil. If it's gear oil you have a leak in the final drive. They don't hold much oil, so make sure it doesn't run dry. Info should be in your owner's manual on checking it and fluid quantity. If it's hydraulic oil, it's from the motor, or one of the fittings or hoses is leaking.
   / Kubota KX-91s has oil leak inside of track near the front under roller #6
Gear oil used in the rollers also and it does turn black, brackish.
Fred
   / Kubota KX-91s has oil leak inside of track near the front under roller #7
Hi Csharpe if you contact our service department we can help you.
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2011 GROVE TMS900E TRUCK CRANE (A50854)
2011 GROVE TMS900E...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
